Hi all,
Building on previous issues I seem to having recently, I am still struggling to get any code to run correctly, nothing has changed software or hardware wise but the x and y axis seem to have a mind of their own.
I managed to get a video this time as its difficult to explain, the operation you see should be a 2d contour of a roughly rectangular shape with heavily radiused corners, it seems to look ok until it hits the first corner then it just has a meltdown.
https://youtu.be/i-yBlTxEtzo
There is an operation before this cutting a couple of shallow slots using the exact same 2d contour settings which runs fine.
Most basic checks have been done, cards formatted, stepper temp ok, continuity checked, code looks fine in NCviewer and Fusions preview, also changed to Guffy’s post processor as suggested in previous post.
The issue has to be somewhere between the sd and the Ramps, it feels like its just missing 90% of the gcode and then jumping to the random coordinates it does get, but I don’t have any parts spare to just swap things out and see if it works, any help or advice would be appreciated.
Did you put the origin in the same place as the other op? Only time I’ve seen this behavior before is when running negative coordinates through the dual endstop firmware. It can do all kinds of bonkers crap.
No i don’t think so, it was part of a setup of 3 operations, to cut out the slots, then the contour and a finishing pass, so the origin is the same for all of them isn’t it, as its set in the setup not the operation itself.
Yes, if they’re all in the same setup, the origin will be the same. It was a long shot, but I had to ask because I haven’t seen that kind of motion any other way.
If path 1 follows the same contour as path 2 and they are in the same setup, I’m stumped.
I sure hope somebody else has some ideas.
I appreciate the input, i’m all out of idea’s apart from rip out the brains and start again so anything is step forward from where I was.
Maybe its a fault with the lcd board as the SD is being read from there, but I can’t rule it out until I check with a known good one, I’m just hoping someone will pipe up and point out I’ve done something wrong in fusion and avoid buying a load of new hardware.
jeffeb3
(Jeffeb3)
August 2, 2020, 3:08pm
7
Can you try with v1pi or repetier host?
jeffeb3:
Can you share the gcode?
I certainly can, but i don’t have a pi, which I know is shameful, but its is the truth
Code
;Fusion 360 CAM 2.0.8624
; Posts processor: DIYCNC_Marlin20.cps
; Gcode generated: Sunday, August 2, 2020 10:46:58 AM GMT
; Document: alternative Current v2
; Setup: Setup3 2
; Ranges table:
; X: Min=-20.102 Max=22.767 Size=42.868
; Y: Min=-33.497 Max=7.506 Size=41.003
; Z: Min=-4.1 Max=15 Size=19.1
; Tools table:
; T1 D=3 CR=0 - ZMIN=-4.1 - flat end mill
; *** START begin ***
G90
G21
M84 S0
G92 X0 Y0 Z0
; *** START end ***
; *** SECTION begin ***
;Slots - Milling - Tool: 1 - flat end mill
; X Min: 3.161 - X Max: 22.767
; Y Min: -10.413 - Y Max: 7.506
; Z Min: -2 - Z Max: 15
; COMMAND_START_SPINDLE
; COMMAND_SPINDLE_CLOCKWISE
M0 Turn ON 10000RPM
; COMMAND_COOLANT_ON
M117 Slots
G0 Z15
G0 X15.342 Y7.505 F2500
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z1 F30
G1 Z-0.7
; MOVEMENT_LEAD_IN
G1 Y7.501 Z-0.747 F250
G1 X15.341 Y7.49 Z-0.793
G1 Y7.472 Z-0.836
G1 X15.34 Y7.448 Z-0.876
G1 X15.339 Y7.417 Z-0.912
G1 X15.338 Y7.381 Z-0.943
G1 X15.337 Y7.341 Z-0.967
G1 X15.336 Y7.298 Z-0.985
G1 X15.334 Y7.252 Z-0.996
G1 X15.333 Y7.205 Z-1
G1 X15.324 Y6.905
G3 X15.614 Y6.596 I0.3 J-0.009
; MOVEMENT_CUTTING
G2 X18.8 Y3.596 I-0.101 J-3.298
G2 X22.371 Y6.125 I3.213 J-0.751
; MOVEMENT_LEAD_OUT
G3 X22.701 Y6.391 I0.033 J0.298
G1 X22.734 Y6.689
G1 X22.739 Y6.736 Z-0.996
G1 X22.744 Y6.781 Z-0.985
G1 X22.749 Y6.825 Z-0.967
G1 X22.753 Y6.864 Z-0.943
G1 X22.757 Y6.9 Z-0.912
G1 X22.76 Y6.93 Z-0.876
G1 X22.763 Y6.955 Z-0.836
G1 X22.765 Y6.973 Z-0.793
G1 X22.766 Y6.984 Z-0.747
G1 X22.767 Y6.987 Z-0.7
; MOVEMENT_RAPID
G0 Z5 F300
G0 X15.333 Y7.205 F2500
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z1 F30
G1 Z-0.7
; MOVEMENT_LEAD_IN
G1 Y7.201 Z-0.747 F250
G1 X15.332 Y7.191 Z-0.793
G1 Y7.172 Z-0.836
G1 X15.331 Y7.148 Z-0.876
G1 X15.33 Y7.117 Z-0.912
G1 X15.329 Y7.082 Z-0.943
G1 X15.328 Y7.041 Z-0.967
G1 X15.326 Y6.998 Z-0.985
G1 X15.325 Y6.952 Z-0.996
G1 X15.324 Y6.905 Z-1
G1 X15.314 Y6.605
G3 X15.605 Y6.296 I0.3 J-0.009
; MOVEMENT_FINISH_CUTTING
G2 X18.513 Y3.298 I-0.092 J-2.999
G1 Y-10.163
G3 X19.013 I0.25
G1 Y2.845
G2 X22.338 Y5.827 I3
; MOVEMENT_LEAD_OUT
G3 X22.669 Y6.093 I0.033 J0.298
G1 X22.701 Y6.391
G1 X22.707 Y6.438 Z-0.996
G1 X22.712 Y6.483 Z-0.985
G1 X22.716 Y6.526 Z-0.967
G1 X22.721 Y6.566 Z-0.943
G1 X22.724 Y6.602 Z-0.912
G1 X22.728 Y6.632 Z-0.876
G1 X22.73 Y6.657 Z-0.836
G1 X22.732 Y6.675 Z-0.793
G1 X22.734 Y6.686 Z-0.747
G1 Y6.689 Z-0.7
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0.5 F30
G1 Z-1.2
; MOVEMENT_LEAD_IN
G1 Y7.501 Z-1.247 F250
G1 X15.341 Y7.49 Z-1.293
G1 Y7.472 Z-1.336
G1 X15.34 Y7.448 Z-1.376
G1 X15.339 Y7.417 Z-1.412
G1 X15.338 Y7.381 Z-1.443
G1 X15.337 Y7.341 Z-1.467
G1 X15.336 Y7.298 Z-1.485
G1 X15.334 Y7.252 Z-1.496
G1 X15.333 Y7.205 Z-1.5
G1 X15.324 Y6.905
; MOVEMENT_CUTTING
; MOVEMENT_LEAD_OUT
G1 X22.734 Y6.689
G1 X22.739 Y6.736 Z-1.496
G1 X22.744 Y6.781 Z-1.485
G1 X22.749 Y6.825 Z-1.467
G1 X22.753 Y6.864 Z-1.443
G1 X22.757 Y6.9 Z-1.412
G1 X22.76 Y6.93 Z-1.376
G1 X22.763 Y6.955 Z-1.336
G1 X22.765 Y6.973 Z-1.293
G1 X22.766 Y6.984 Z-1.247
G1 X22.767 Y6.987 Z-1.2
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0.5 F30
G1 Z-1.2
; MOVEMENT_LEAD_IN
G1 Y7.201 Z-1.247 F250
G1 X15.332 Y7.191 Z-1.293
G1 Y7.172 Z-1.336
G1 X15.331 Y7.148 Z-1.376
G1 X15.33 Y7.117 Z-1.412
G1 X15.329 Y7.082 Z-1.443
G1 X15.328 Y7.041 Z-1.467
G1 X15.326 Y6.998 Z-1.485
G1 X15.325 Y6.952 Z-1.496
G1 X15.324 Y6.905 Z-1.5
G1 X15.314 Y6.605
G1 Y-10.163
G3 X19.013 I0.25
G1 Y2.845
; MOVEMENT_LEAD_OUT
G1 X22.701 Y6.391
G1 X22.707 Y6.438 Z-1.496
G1 X22.712 Y6.483 Z-1.485
G1 X22.716 Y6.526 Z-1.467
G1 X22.721 Y6.566 Z-1.443
G1 X22.724 Y6.602 Z-1.412
G1 X22.728 Y6.632 Z-1.376
G1 X22.73 Y6.657 Z-1.336
G1 X22.732 Y6.675 Z-1.293
G1 X22.734 Y6.686 Z-1.247
G1 Y6.689 Z-1.2
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0 F30
G1 Z-1.7
; MOVEMENT_LEAD_IN
G1 Y7.501 Z-1.747 F250
G1 X15.341 Y7.49 Z-1.793
G1 Y7.472 Z-1.836
G1 X15.34 Y7.448 Z-1.876
G1 X15.339 Y7.417 Z-1.912
G1 X15.338 Y7.381 Z-1.943
G1 X15.337 Y7.341 Z-1.967
G1 X15.336 Y7.298 Z-1.985
G1 X15.334 Y7.252 Z-1.996
G1 X15.333 Y7.205 Z-2
G1 X15.324 Y6.905
; MOVEMENT_CUTTING
; MOVEMENT_LEAD_OUT
G1 X22.734 Y6.689
G1 X22.739 Y6.736 Z-1.996
G1 X22.744 Y6.781 Z-1.985
G1 X22.749 Y6.825 Z-1.967
G1 X22.753 Y6.864 Z-1.943
G1 X22.757 Y6.9 Z-1.912
G1 X22.76 Y6.93 Z-1.876
G1 X22.763 Y6.955 Z-1.836
G1 X22.765 Y6.973 Z-1.793
G1 X22.766 Y6.984 Z-1.747
G1 X22.767 Y6.987 Z-1.7
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0 F30
G1 Z-1.7
; MOVEMENT_LEAD_IN
G1 Y7.201 Z-1.747 F250
G1 X15.332 Y7.191 Z-1.793
G1 Y7.172 Z-1.836
G1 X15.331 Y7.148 Z-1.876
G1 X15.33 Y7.117 Z-1.912
G1 X15.329 Y7.082 Z-1.943
G1 X15.328 Y7.041 Z-1.967
G1 X15.326 Y6.998 Z-1.985
G1 X15.325 Y6.952 Z-1.996
G1 X15.324 Y6.905 Z-2
G1 X15.314 Y6.605
G1 Y-10.163
G3 X19.013 I0.25
G1 Y2.845
; MOVEMENT_LEAD_OUT
G1 X22.701 Y6.391
G1 X22.707 Y6.438 Z-1.996
G1 X22.712 Y6.483 Z-1.985
G1 X22.716 Y6.526 Z-1.967
G1 X22.721 Y6.566 Z-1.943
G1 X22.724 Y6.602 Z-1.912
G1 X22.728 Y6.632 Z-1.876
G1 X22.73 Y6.657 Z-1.836
G1 X22.732 Y6.675 Z-1.793
G1 X22.734 Y6.686 Z-1.747
G1 Y6.689 Z-1.7
; MOVEMENT_RAPID
G0 Z5 F300
G0 X3.161 Y6.991 F2500
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z1 F30
G1 Z-0.7
; MOVEMENT_LEAD_IN
G1 X3.162 Y6.987 Z-0.747 F250
G1 X3.163 Y6.976 Z-0.793
G1 X3.165 Y6.958 Z-0.836
G1 X3.167 Y6.934 Z-0.876
G1 X3.171 Y6.903 Z-0.912
G1 X3.175 Y6.868 Z-0.943
G1 X3.179 Y6.828 Z-0.967
G1 X3.184 Y6.785 Z-0.985
G1 X3.188 Y6.739 Z-0.996
G1 X3.194 Y6.692 Z-1
G1 X3.226 Y6.394
G3 X3.557 Y6.128 I0.298 J0.032
; MOVEMENT_CUTTING
G2 X7.127 Y3.598 I0.356 J-3.281
G2 X10.313 Y6.597 I3.286 J-0.299
; MOVEMENT_LEAD_OUT
G3 X10.604 Y6.906 I-0.009 J0.3
G1 X10.595 Y7.206
G1 X10.593 Y7.253 Z-0.996
G1 X10.592 Y7.299 Z-0.985
G1 X10.591 Y7.342 Z-0.967
G1 X10.589 Y7.382 Z-0.943
G1 X10.588 Y7.418 Z-0.912
G1 X10.587 Y7.449 Z-0.876
G1 Y7.473 Z-0.836
G1 X10.586 Y7.491 Z-0.793
G1 Y7.502 Z-0.747
G1 Y7.506 Z-0.7
; MOVEMENT_RAPID
G0 Z5 F300
G0 X3.194 Y6.692 F2500
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z1 F30
G1 Z-0.7
; MOVEMENT_LEAD_IN
G1 Y6.689 Z-0.747 F250
G1 X3.195 Y6.678 Z-0.793
G1 X3.197 Y6.66 Z-0.836
G1 X3.2 Y6.635 Z-0.876
G1 X3.203 Y6.605 Z-0.912
G1 X3.207 Y6.57 Z-0.943
G1 X3.211 Y6.53 Z-0.967
G1 X3.216 Y6.486 Z-0.985
G1 X3.221 Y6.441 Z-0.996
G1 X3.226 Y6.394 Z-1
G1 X3.258 Y6.096
G3 X3.589 Y5.83 I0.298 J0.032
G2 X6.913 Y2.848 I0.324 J-2.982
G1 Y-10.163
G3 X7.413 I0.25
G1 Y3.299
G2 X10.322 Y6.297 I3
; MOVEMENT_LEAD_OUT
G3 X10.613 Y6.606 I-0.009 J0.3
G1 X10.604 Y6.906
G1 X10.602 Y6.953 Z-0.996
G1 X10.601 Y6.999 Z-0.985
G1 X10.6 Y7.042 Z-0.967
G1 X10.599 Y7.082 Z-0.943
G1 X10.597 Y7.118 Z-0.912
G1 Y7.149 Z-0.876
G1 X10.596 Y7.173 Z-0.836
G1 X10.595 Y7.191 Z-0.793
G1 Y7.202 Z-0.747
G1 Y7.206 Z-0.7
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0.5 F30
G1 Z-1.2
; MOVEMENT_LEAD_IN
G1 X3.162 Y6.987 Z-1.247 F250
G1 X3.163 Y6.976 Z-1.293
G1 X3.165 Y6.958 Z-1.336
G1 X3.167 Y6.934 Z-1.376
G1 X3.171 Y6.903 Z-1.412
G1 X3.175 Y6.868 Z-1.443
G1 X3.179 Y6.828 Z-1.467
G1 X3.184 Y6.785 Z-1.485
G1 X3.188 Y6.739 Z-1.496
G1 X3.194 Y6.692 Z-1.5
G1 X3.226 Y6.394
; MOVEMENT_CUTTING
; MOVEMENT_LEAD_OUT
G1 X10.595 Y7.206
G1 X10.593 Y7.253 Z-1.496
G1 X10.592 Y7.299 Z-1.485
G1 X10.591 Y7.342 Z-1.467
G1 X10.589 Y7.382 Z-1.443
G1 X10.588 Y7.418 Z-1.412
G1 X10.587 Y7.449 Z-1.376
G1 Y7.473 Z-1.336
G1 X10.586 Y7.491 Z-1.293
G1 Y7.502 Z-1.247
G1 Y7.506 Z-1.2
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0.5 F30
G1 Z-1.2
; MOVEMENT_LEAD_IN
G1 Y6.689 Z-1.247 F250
G1 X3.195 Y6.678 Z-1.293
G1 X3.197 Y6.66 Z-1.336
G1 X3.2 Y6.635 Z-1.376
G1 X3.203 Y6.605 Z-1.412
G1 X3.207 Y6.57 Z-1.443
G1 X3.211 Y6.53 Z-1.467
G1 X3.216 Y6.486 Z-1.485
G1 X3.221 Y6.441 Z-1.496
G1 X3.226 Y6.394 Z-1.5
G1 X3.258 Y6.096
G1 Y-10.163
G3 X7.413 I0.25
G1 Y3.299
; MOVEMENT_LEAD_OUT
G1 X10.604 Y6.906
G1 X10.602 Y6.953 Z-1.496
G1 X10.601 Y6.999 Z-1.485
G1 X10.6 Y7.042 Z-1.467
G1 X10.599 Y7.082 Z-1.443
G1 X10.597 Y7.118 Z-1.412
G1 Y7.149 Z-1.376
G1 X10.596 Y7.173 Z-1.336
G1 X10.595 Y7.191 Z-1.293
G1 Y7.202 Z-1.247
G1 Y7.206 Z-1.2
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0 F30
G1 Z-1.7
; MOVEMENT_LEAD_IN
G1 X3.162 Y6.987 Z-1.747 F250
G1 X3.163 Y6.976 Z-1.793
G1 X3.165 Y6.958 Z-1.836
G1 X3.167 Y6.934 Z-1.876
G1 X3.171 Y6.903 Z-1.912
G1 X3.175 Y6.868 Z-1.943
G1 X3.179 Y6.828 Z-1.967
G1 X3.184 Y6.785 Z-1.985
G1 X3.188 Y6.739 Z-1.996
G1 X3.194 Y6.692 Z-2
G1 X3.226 Y6.394
; MOVEMENT_CUTTING
; MOVEMENT_LEAD_OUT
G1 X10.595 Y7.206
G1 X10.593 Y7.253 Z-1.996
G1 X10.592 Y7.299 Z-1.985
G1 X10.591 Y7.342 Z-1.967
G1 X10.589 Y7.382 Z-1.943
G1 X10.588 Y7.418 Z-1.912
G1 X10.587 Y7.449 Z-1.876
G1 Y7.473 Z-1.836
G1 X10.586 Y7.491 Z-1.793
G1 Y7.502 Z-1.747
G1 Y7.506 Z-1.7
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0 F30
G1 Z-1.7
; MOVEMENT_LEAD_IN
G1 Y6.689 Z-1.747 F250
G1 X3.195 Y6.678 Z-1.793
G1 X3.197 Y6.66 Z-1.836
G1 X3.2 Y6.635 Z-1.876
G1 X3.203 Y6.605 Z-1.912
G1 X3.207 Y6.57 Z-1.943
G1 X3.211 Y6.53 Z-1.967
G1 X3.216 Y6.486 Z-1.985
G1 X3.221 Y6.441 Z-1.996
G1 X3.226 Y6.394 Z-2
G1 X3.258 Y6.096
G1 Y-10.163
G3 X7.413 I0.25
G1 Y3.299
; MOVEMENT_LEAD_OUT
G1 X10.604 Y6.906
G1 X10.602 Y6.953 Z-1.996
G1 X10.601 Y6.999 Z-1.985
G1 X10.6 Y7.042 Z-1.967
G1 X10.599 Y7.082 Z-1.943
G1 X10.597 Y7.118 Z-1.912
G1 Y7.149 Z-1.876
G1 X10.596 Y7.173 Z-1.836
G1 X10.595 Y7.191 Z-1.793
G1 Y7.202 Z-1.747
G1 Y7.206 Z-1.7
; MOVEMENT_RAPID
G0 Z15 F300
; *** SECTION end ***
;Main_Cutout - Milling - Tool: 1 - flat end mill
; X Min: -19.902 - X Max: 45.934
; Y Min: -33.297 - Y Max: 6.437
; Z Min: -3.5 - Z Max: 15
M117 Main_Cutout
G0 Z15 F300
G0 X-11.859 Y4.286 F2500
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z1 F30
G1 Z-0.7
; MOVEMENT_LEAD_IN
G1 X-11.858 Y4.282 Z-0.747 F120
G1 X-11.855 Y4.271 Z-0.793
G1 X-11.851 Y4.254 Z-0.836
G1 X-11.846 Y4.23 Z-0.876
G1 X-11.839 Y4.2 Z-0.912
G1 X-11.83 Y4.165 Z-0.943
G1 X-11.821 Y4.126 Z-0.967
G1 X-11.811 Y4.084 Z-0.985
G1 X-11.801 Y4.039 Z-0.996
G1 X-11.79 Y3.994 Z-1
G1 X-11.721 Y3.702
G3 X-11.36 Y3.479 I0.292 J0.069
G2 X-10.611 Y3.632 I2.788 J-11.774 F360
G1 X-7.855 Y4.106
G1 X-5.1 Y4.589
G1 X-2.347 Y5.078
G2 X28.001 Y5.122 I15.296 J-85.403
G1 X30.876 Y4.619
G1 X33.752 Y4.125
G1 X36.63 Y3.638
G2 X37.119 Y3.546 I-2.001 J-11.933
G2 X40.299 Y2.345 I-2.284 J-10.862
G2 X42.671 Y0.544 I-4.476 J-8.359
G2 X45.136 Y-11.451 I-7.837 J-7.861
G3 Y-18.041 I8.211 J-3.295
G2 X37.119 Y-33.038 I-10.301 J-4.134
G2 X30.444 Y-32.55 I-2.49 J11.841
G3 X-4.386 I-17.415 J-47.24
G2 X-11.36 Y-32.971 I-4.185 J11.353
G2 X-19.116 Y-18.068 I2.558 J10.801
G3 Y-11.424 I-8.353 J3.322
G2 X-18.003 Y-1.114 I10.314 J4.102
G2 X-11.36 Y3.479 I9.202 J-6.208
; MOVEMENT_LEAD_OUT
G3 X-11.137 Y3.84 I-0.069 J0.292 F120
G1 X-11.206 Y4.132
G1 X-11.217 Y4.178 Z-0.996
G1 X-11.227 Y4.222 Z-0.985
G1 X-11.237 Y4.264 Z-0.967
G1 X-11.246 Y4.304 Z-0.943
G1 X-11.255 Y4.338 Z-0.912
G1 X-11.262 Y4.368 Z-0.876
G1 X-11.267 Y4.392 Z-0.836
G1 X-11.272 Y4.41 Z-0.793
G1 X-11.274 Y4.42 Z-0.747
G1 X-11.275 Y4.424 Z-0.7
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0.5 F30
G1 Z-1.2
; MOVEMENT_LEAD_IN
G1 X-11.858 Y4.282 Z-1.247 F120
G1 X-11.855 Y4.271 Z-1.293
G1 X-11.851 Y4.254 Z-1.336
G1 X-11.846 Y4.23 Z-1.376
G1 X-11.839 Y4.2 Z-1.412
G1 X-11.83 Y4.165 Z-1.443
G1 X-11.821 Y4.126 Z-1.467
G1 X-11.811 Y4.084 Z-1.485
G1 X-11.801 Y4.039 Z-1.496
G1 X-11.79 Y3.994 Z-1.5
G1 X-11.721 Y3.702
G1 X-7.855 Y4.106
G1 X-5.1 Y4.589
G1 X-2.347 Y5.078
G1 X30.876 Y4.619
G1 X33.752 Y4.125
G1 X36.63 Y3.638
; MOVEMENT_LEAD_OUT
G1 X-11.206 Y4.132
G1 X-11.217 Y4.178 Z-1.496
G1 X-11.227 Y4.222 Z-1.485
G1 X-11.237 Y4.264 Z-1.467
G1 X-11.246 Y4.304 Z-1.443
G1 X-11.255 Y4.338 Z-1.412
G1 X-11.262 Y4.368 Z-1.376
G1 X-11.267 Y4.392 Z-1.336
G1 X-11.272 Y4.41 Z-1.293
G1 X-11.274 Y4.42 Z-1.247
G1 X-11.275 Y4.424 Z-1.2
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0 F30
G1 Z-1.7
; MOVEMENT_LEAD_IN
G1 X-11.858 Y4.282 Z-1.747 F120
G1 X-11.855 Y4.271 Z-1.793
G1 X-11.851 Y4.254 Z-1.836
G1 X-11.846 Y4.23 Z-1.876
G1 X-11.839 Y4.2 Z-1.912
G1 X-11.83 Y4.165 Z-1.943
G1 X-11.821 Y4.126 Z-1.967
G1 X-11.811 Y4.084 Z-1.985
G1 X-11.801 Y4.039 Z-1.996
G1 X-11.79 Y3.994 Z-2
G1 X-11.721 Y3.702
G1 X-7.855 Y4.106
G1 X-5.1 Y4.589
G1 X-2.347 Y5.078
G1 X30.876 Y4.619
G1 X33.752 Y4.125
G1 X36.63 Y3.638
; MOVEMENT_LEAD_OUT
G1 X-11.206 Y4.132
G1 X-11.217 Y4.178 Z-1.996
G1 X-11.227 Y4.222 Z-1.985
G1 X-11.237 Y4.264 Z-1.967
G1 X-11.246 Y4.304 Z-1.943
G1 X-11.255 Y4.338 Z-1.912
G1 X-11.262 Y4.368 Z-1.876
G1 X-11.267 Y4.392 Z-1.836
G1 X-11.272 Y4.41 Z-1.793
G1 X-11.274 Y4.42 Z-1.747
G1 X-11.275 Y4.424 Z-1.7
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z-0.5 F30
G1 Z-2.2
; MOVEMENT_LEAD_IN
G1 X-11.858 Y4.282 Z-2.247 F120
G1 X-11.855 Y4.271 Z-2.293
G1 X-11.851 Y4.254 Z-2.336
G1 X-11.846 Y4.23 Z-2.376
G1 X-11.839 Y4.2 Z-2.412
G1 X-11.83 Y4.165 Z-2.443
G1 X-11.821 Y4.126 Z-2.467
G1 X-11.811 Y4.084 Z-2.485
G1 X-11.801 Y4.039 Z-2.496
G1 X-11.79 Y3.994 Z-2.5
G1 X-11.721 Y3.702
G1 X-7.855 Y4.106
G1 X-5.1 Y4.589
G1 X-2.347 Y5.078
G1 X30.876 Y4.619
G1 X33.752 Y4.125
G1 X36.63 Y3.638
; MOVEMENT_LEAD_OUT
G1 X-11.206 Y4.132
G1 X-11.217 Y4.178 Z-2.496
G1 X-11.227 Y4.222 Z-2.485
G1 X-11.237 Y4.264 Z-2.467
G1 X-11.246 Y4.304 Z-2.443
G1 X-11.255 Y4.338 Z-2.412
G1 X-11.262 Y4.368 Z-2.376
G1 X-11.267 Y4.392 Z-2.336
G1 X-11.272 Y4.41 Z-2.293
G1 X-11.274 Y4.42 Z-2.247
G1 X-11.275 Y4.424 Z-2.2
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z-1 F30
G1 Z-2.7
; MOVEMENT_LEAD_IN
G1 X-11.858 Y4.282 Z-2.747 F120
G1 X-11.855 Y4.271 Z-2.793
G1 X-11.851 Y4.254 Z-2.836
G1 X-11.846 Y4.23 Z-2.876
G1 X-11.839 Y4.2 Z-2.912
G1 X-11.83 Y4.165 Z-2.943
G1 X-11.821 Y4.126 Z-2.967
G1 X-11.811 Y4.084 Z-2.985
G1 X-11.801 Y4.039 Z-2.996
G1 X-11.79 Y3.994 Z-3
G1 X-11.721 Y3.702
G1 X-7.855 Y4.106
G1 X-5.1 Y4.589
G1 X-2.347 Y5.078
G1 X30.876 Y4.619
G1 X33.752 Y4.125
G1 X36.63 Y3.638
; MOVEMENT_LEAD_OUT
G1 X-11.206 Y4.132
G1 X-11.217 Y4.178 Z-2.996
G1 X-11.227 Y4.222 Z-2.985
G1 X-11.237 Y4.264 Z-2.967
G1 X-11.246 Y4.304 Z-2.943
G1 X-11.255 Y4.338 Z-2.912
G1 X-11.262 Y4.368 Z-2.876
G1 X-11.267 Y4.392 Z-2.836
G1 X-11.272 Y4.41 Z-2.793
G1 X-11.274 Y4.42 Z-2.747
G1 X-11.275 Y4.424 Z-2.7
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z-1.5 F30
G1 Z-3.2
; MOVEMENT_LEAD_IN
G1 X-11.858 Y4.282 Z-3.247 F120
G1 X-11.855 Y4.271 Z-3.293
G1 X-11.851 Y4.254 Z-3.336
G1 X-11.846 Y4.23 Z-3.376
G1 X-11.839 Y4.2 Z-3.412
G1 X-11.83 Y4.165 Z-3.443
G1 X-11.821 Y4.126 Z-3.467
G1 X-11.811 Y4.084 Z-3.485
G1 X-11.801 Y4.039 Z-3.496
G1 X-11.79 Y3.994 Z-3.5
G1 X-11.721 Y3.702
G1 X-7.855 Y4.106
G1 X-5.1 Y4.589
G1 X-2.347 Y5.078
G1 X30.876 Y4.619
G1 X33.752 Y4.125
G1 X36.63 Y3.638
; MOVEMENT_LEAD_OUT
G1 X-11.206 Y4.132
G1 X-11.217 Y4.178 Z-3.496
G1 X-11.227 Y4.222 Z-3.485
G1 X-11.237 Y4.264 Z-3.467
G1 X-11.246 Y4.304 Z-3.443
G1 X-11.255 Y4.338 Z-3.412
G1 X-11.262 Y4.368 Z-3.376
G1 X-11.267 Y4.392 Z-3.336
G1 X-11.272 Y4.41 Z-3.293
G1 X-11.274 Y4.42 Z-3.247
G1 X-11.275 Y4.424 Z-3.2
; MOVEMENT_RAPID
G0 Z15 F300
;Finish - Milling - Tool: 1 - flat end mill
; X Min: -20.102 - X Max: 46.134
; Y Min: -33.497 - Y Max: 6.637
; Z Min: -4.1 - Z Max: 15
M117 Finish
G0 Z15 F300
G0 X-11.905 Y4.48 F2500
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0.5 F30
G1 Z-3.8
; MOVEMENT_LEAD_IN
G1 X-11.904 Y4.477 Z-3.847 F120
G1 X-11.902 Y4.466 Z-3.893
G1 X-11.897 Y4.448 Z-3.936
G1 X-11.892 Y4.424 Z-3.976
G1 X-11.885 Y4.395 Z-4.012
G1 X-11.876 Y4.36 Z-4.043
G1 X-11.867 Y4.321 Z-4.067
G1 X-11.857 Y4.279 Z-4.085
G1 X-11.847 Y4.234 Z-4.096
G1 X-11.836 Y4.188 Z-4.1
G1 X-11.767 Y3.896
G3 X-11.406 Y3.674 I0.292 J0.069
; MOVEMENT_CUTTING
G2 X-10.644 Y3.829 I2.834 J-11.969 F360
G1 X-8.122 Y4.263
G1 Z-3.5
G1 X-5.251 Y4.765
G1 X-2.382 Y5.275
G2 X-2.213 Y5.305 I15.331 J-85.6
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
G2 X9.447 Y6.567 I15.162 J-85.63 F360
G1 Z-3.5
G2 X15.447 Y6.601 I3.502 J-86.892
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
G2 X28.035 Y5.319 I-2.498 J-86.926 F360
G1 X29.776 Y5.013
G1 Z-3.5
G1 X31.747 Y4.672
G1 X33.718 Y4.333
G1 X35.69 Y3.999
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
G1 X36.663 Y3.835 F360
G2 X37.16 Y3.741 I-2.034 J-12.131
G2 X40.396 Y2.52 I-2.325 J-11.058
G2 X42.814 Y0.684 I-4.572 J-8.534
G2 X45.038 Y-2.462 I-7.98 J-8.001
G1 Z-3.5
G2 X46.085 Y-8.369 I-10.204 J-4.855
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
G2 X45.322 Y-11.525 I-11.251 J1.053 F360
G3 Y-17.967 I8.025 J-3.221
G2 X46.134 Y-22.097 I-10.487 J-4.209
G1 Z-3.5
G2 X44.581 Y-27.893 I-11.3 J-0.078
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
G2 X40.012 Y-32.219 I-9.747 J5.717 F360
G1 Z-3.5
G2 X37.16 Y-33.234 I-5.178 J10.044
G2 X34.148 Y-33.487 I-2.531 J12.037
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
G2 X30.374 Y-32.738 I0.481 J12.291 F360
G3 X-4.317 I-17.346 J-47.052
G2 X-9.833 Y-33.432 I-4.254 J11.541
G1 Z-3.5
G2 X-11.406 Y-33.166 I1.261 J12.235
G2 X-15.445 Y-31.311 I2.604 J10.996
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
G2 X-18.518 Y-27.939 I6.644 J9.141 F360
G1 Z-3.5
G2 X-20.102 Y-22.152 I9.716 J5.769
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
G2 X-19.302 Y-17.994 I11.3 J-0.018 F360
G3 Y-11.498 I-8.167 J3.248
G2 X-20.003 Y-8.812 I10.5 J4.176
G1 Z-3.5
G2 X-19.186 Y-2.868 I11.201 J1.489
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
G2 X-11.406 Y3.674 I10.385 J-4.455 F360
; MOVEMENT_LINK_TRANSITION
G2 X-11.15 Y3.578 I0.056 J-0.238
G3 X-10.897 Y3.477 I0.205 J0.146
G2 X-10.594 Y3.533 I2.325 J-11.773
G1 X-8.07 Y3.968
G1 Z-3.5
G1 X-5.199 Y4.47
G1 X-2.329 Y4.98
G2 X-2.161 Y5.01 I15.278 J-85.305
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
G2 X9.449 Y6.266 I15.11 J-85.335 F360
G1 Z-3.5
G2 X15.449 Y6.301 I3.5 J-86.591
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
G2 X27.983 Y5.023 I-2.5 J-86.626 F360
G1 X29.725 Y4.718
G1 Z-3.5
G1 X31.696 Y4.376
G1 X33.667 Y4.038
G1 X35.639 Y3.703
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
G1 X36.614 Y3.539 F360
G2 X37.098 Y3.448 I-1.985 J-11.835
G2 X40.251 Y2.257 I-2.264 J-10.765
G2 X42.6 Y0.474 I-4.428 J-8.271
G2 X44.732 Y-2.516 I-7.765 J-7.791
G1 Z-3.5
G2 X45.779 Y-8.424 I-9.897 J-4.801
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
G2 X45.043 Y-11.414 I-10.944 J1.107 F360
G3 Y-18.078 I8.304 J-3.332
G2 X45.833 Y-22.017 I-10.209 J-4.097
G1 Z-3.5
G2 X44.281 Y-27.812 I-10.999 J-0.159
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
G2 X39.948 Y-31.915 I-9.446 J5.637 F360
G1 Z-3.5
G2 X37.098 Y-32.94 I-5.114 J9.739
G2 X34.084 Y-33.184 I-2.469 J11.743
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
G2 X30.478 Y-32.456 I0.545 J11.988 F360
G3 X-4.42 I-17.449 J-47.334
G2 X-9.723 Y-33.141 I-4.151 J11.259
G1 Z-3.5
G2 X-11.336 Y-32.874 I1.152 J11.945
G2 X-15.335 Y-31.019 I2.535 J10.704
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
G2 X-18.217 Y-27.857 I6.534 J8.849 F360
G1 Z-3.5
G2 X-19.801 Y-22.07 I9.416 J5.687
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
G2 X-19.023 Y-18.105 I11 J-0.1 F360
G3 Y-11.387 I-8.446 J3.359
G2 X-19.694 Y-8.854 I10.221 J4.065
G1 Z-3.5
G2 X-18.878 Y-2.91 I10.893 J1.532
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
G2 X-17.92 Y-1.17 I10.076 J-4.412 F360
G2 X-11.336 Y3.382 I9.119 J-6.152
G2 X-10.897 Y3.477 I2.765 J-11.677
; MOVEMENT_LEAD_OUT
G3 X-10.661 Y3.83 I-0.058 J0.294 F120
G1 X-10.719 Y4.124
G1 X-10.728 Y4.17 Z-4.096
G1 X-10.737 Y4.215 Z-4.085
G1 X-10.745 Y4.257 Z-4.067
G1 X-10.753 Y4.297 Z-4.043
G1 X-10.76 Y4.332 Z-4.012
G1 X-10.766 Y4.362 Z-3.976
G1 X-10.77 Y4.386 Z-3.936
G1 X-10.774 Y4.404 Z-3.893
G1 X-10.776 Y4.415 Z-3.847
G1 X-10.777 Y4.418 Z-3.8
; MOVEMENT_RAPID
G0 Z15 F300
; *** STOP begin ***
M400
; COMMAND_COOLANT_OFF
G0 X0 Y0 F2500
; COMMAND_STOP_SPINDLE
M300 S300 P3000
M0 Turn OFF spindle
M117 Job end
; *** STOP end ***
I put it through NCviewer and, to me it looks fine, but obviously something is being lost somewhere.
jeffeb3
(Jeffeb3)
August 2, 2020, 4:01pm
9
It does look fine in ncviewer. I have not idea why the G2/G3 commands might be giving you trouble, but they are still in there. I thought the workaround before was to take those out?
We can look closely at the firmware you have, and maybe update it to fix the arcs. Or we can focus on the LCD and try to come up with another way to send gcode (to eliminate noise as the source). Or we can focus on CAM to remove the arcs.
jeffeb3
(Jeffeb3)
August 2, 2020, 4:02pm
10
I wouldn’t think dumping the electronics and buying new stuff is going to help anyone until we know where the problem is.
Sorry, yes you are right, but removing the G2/G3 commands only stops the wild movements, the code is still not being communicated to the steppers correctly,
I took another vid of just the G1 commands and it just moves back and forth in x, but it does move slightly in Y maybe an 1/10 of a rotation under power, so its not like its completely dead and the multiple z movements are new, no idea what that is.
https://youtu.be/x4CDiwVXgPQ
I didn’t mean to sound overly dramatic or defeatist when I say replace the electronics, It just seemed to me that with the code being ok and the cabling and steppers all testing ok, surely that only leaves whats lies in between, a comment in the last topic mentioned that re flashing Marlin was unlikely to make any difference, so in my head that only left the board or the lcd at fault somehow.
I have an SKR 1.3, with a touch screen in a project 3d printer, is there any reason I can’t strip that out, swap the drivers over and try that?
Also thanks for the help, I don’t think I mentioned that before.
jeffeb3
(Jeffeb3)
August 2, 2020, 5:26pm
12
Can you post the gcode without the arcs?
jeffeb3
(Jeffeb3)
August 2, 2020, 5:27pm
13
What controller do you have now, and what firmware version do you have?
jchaager
(CaptCosmic)
August 2, 2020, 5:38pm
14
Have you double checked all the stepper wiring connections? I have had problems in specific parts of the axes range of motion due to flexing of the connectors causing intermittent breaks in the connections and stuttering in the movement.
Sorry, distracted by dinner and kids.
Marlin-MPCNC_Ramps_T8_16T_LCD_32step_DualEndstop
RAMPS 1.4
Mega 2560
12864 LCD Controller
DRV8825 Driver
I guess I had better check this, but putting a “;” in front does make it invisible doesn’t it, as in I just changes all the G2/G3 for ;G2/;G3, just in case I made a rookie error?
Code
; Setup: Setup3 2
; Ranges table:
; Tools table:
G90
;g21
M84 S0
G92 X0 Y0 Z0
; *** START end ***
M0 Turn ON 10000RPM
M117 Slots
G0 Z15
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z1 F30
G1 Z-0.7
; MOVEMENT_LEAD_IN
G1 Y7.472 Z-0.836
G1 X15.324 Y6.905
;g3 X15.614 Y6.596 I0.3 J-0.009
; MOVEMENT_CUTTING
;g2 X18.8 Y3.596 I-0.101 J-3.298
;g2 X22.371 Y6.125 I3.213 J-0.751
; MOVEMENT_LEAD_OUT
;g3 X22.701 Y6.391 I0.033 J0.298
G1 X22.734 Y6.689
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z1 F30
G1 Z-0.7
; MOVEMENT_LEAD_IN
G1 Y7.172 Z-0.836
G1 X15.314 Y6.605
;g3 X15.605 Y6.296 I0.3 J-0.009
;g2 X18.513 Y3.298 I-0.092 J-2.999
G1 Y-10.163
;g3 X19.013 I0.25
G1 Y2.845
;g2 X22.338 Y5.827 I3
; MOVEMENT_LEAD_OUT
;g3 X22.669 Y6.093 I0.033 J0.298
G1 X22.701 Y6.391
G1 Y6.689 Z-0.7
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0.5 F30
G1 Z-1.2
; MOVEMENT_LEAD_IN
G1 Y7.472 Z-1.336
G1 X15.324 Y6.905
; MOVEMENT_CUTTING
; MOVEMENT_LEAD_OUT
G1 X22.734 Y6.689
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0.5 F30
G1 Z-1.2
; MOVEMENT_LEAD_IN
G1 Y7.172 Z-1.336
G1 X15.314 Y6.605
G1 Y-10.163
;g3 X19.013 I0.25
G1 Y2.845
; MOVEMENT_LEAD_OUT
G1 X22.701 Y6.391
G1 Y6.689 Z-1.2
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0 F30
G1 Z-1.7
; MOVEMENT_LEAD_IN
G1 Y7.472 Z-1.836
G1 X15.324 Y6.905
; MOVEMENT_CUTTING
; MOVEMENT_LEAD_OUT
G1 X22.734 Y6.689
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0 F30
G1 Z-1.7
; MOVEMENT_LEAD_IN
G1 Y7.172 Z-1.836
G1 X15.314 Y6.605
G1 Y-10.163
;g3 X19.013 I0.25
G1 Y2.845
; MOVEMENT_LEAD_OUT
G1 X22.701 Y6.391
G1 Y6.689 Z-1.7
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z1 F30
G1 Z-0.7
; MOVEMENT_LEAD_IN
G1 X3.226 Y6.394
;g3 X3.557 Y6.128 I0.298 J0.032
; MOVEMENT_CUTTING
;g2 X7.127 Y3.598 I0.356 J-3.281
;g2 X10.313 Y6.597 I3.286 J-0.299
; MOVEMENT_LEAD_OUT
;g3 X10.604 Y6.906 I-0.009 J0.3
G1 X10.595 Y7.206
G1 Y7.473 Z-0.836
G1 Y7.502 Z-0.747
G1 Y7.506 Z-0.7
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z1 F30
G1 Z-0.7
; MOVEMENT_LEAD_IN
G1 X3.258 Y6.096
;g3 X3.589 Y5.83 I0.298 J0.032
;g2 X6.913 Y2.848 I0.324 J-2.982
G1 Y-10.163
;g3 X7.413 I0.25
G1 Y3.299
;g2 X10.322 Y6.297 I3
; MOVEMENT_LEAD_OUT
;g3 X10.613 Y6.606 I-0.009 J0.3
G1 X10.604 Y6.906
G1 Y7.149 Z-0.876
G1 Y7.202 Z-0.747
G1 Y7.206 Z-0.7
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0.5 F30
G1 Z-1.2
; MOVEMENT_LEAD_IN
G1 X3.226 Y6.394
; MOVEMENT_CUTTING
; MOVEMENT_LEAD_OUT
G1 X10.595 Y7.206
G1 Y7.473 Z-1.336
G1 Y7.502 Z-1.247
G1 Y7.506 Z-1.2
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0.5 F30
G1 Z-1.2
; MOVEMENT_LEAD_IN
G1 X3.258 Y6.096
G1 Y-10.163
;g3 X7.413 I0.25
G1 Y3.299
; MOVEMENT_LEAD_OUT
G1 X10.604 Y6.906
G1 Y7.149 Z-1.376
G1 Y7.202 Z-1.247
G1 Y7.206 Z-1.2
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0 F30
G1 Z-1.7
; MOVEMENT_LEAD_IN
G1 X3.226 Y6.394
; MOVEMENT_CUTTING
; MOVEMENT_LEAD_OUT
G1 X10.595 Y7.206
G1 Y7.473 Z-1.836
G1 Y7.502 Z-1.747
G1 Y7.506 Z-1.7
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0 F30
G1 Z-1.7
; MOVEMENT_LEAD_IN
G1 X3.258 Y6.096
G1 Y-10.163
;g3 X7.413 I0.25
G1 Y3.299
; MOVEMENT_LEAD_OUT
G1 X10.604 Y6.906
G1 Y7.149 Z-1.876
G1 Y7.202 Z-1.747
G1 Y7.206 Z-1.7
; MOVEMENT_RAPID
G0 Z15 F300
M117 Main_Cutout
G0 Z15 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z1 F30
G1 Z-0.7
; MOVEMENT_LEAD_IN
G1 X-11.721 Y3.702
;g3 X-11.36 Y3.479 I0.292 J0.069
;g2 X-10.611 Y3.632 I2.788 J-11.774 F360
G1 X-7.855 Y4.106
G1 X-5.1 Y4.589
G1 X-2.347 Y5.078
;g2 X28.001 Y5.122 I15.296 J-85.403
G1 X30.876 Y4.619
G1 X33.752 Y4.125
G1 X36.63 Y3.638
;g2 X37.119 Y3.546 I-2.001 J-11.933
;g2 X40.299 Y2.345 I-2.284 J-10.862
;g2 X42.671 Y0.544 I-4.476 J-8.359
;g2 X45.136 Y-11.451 I-7.837 J-7.861
;g3 Y-18.041 I8.211 J-3.295
;g2 X37.119 Y-33.038 I-10.301 J-4.134
;g2 X30.444 Y-32.55 I-2.49 J11.841
;g3 X-4.386 I-17.415 J-47.24
;g2 X-11.36 Y-32.971 I-4.185 J11.353
;g2 X-19.116 Y-18.068 I2.558 J10.801
;g3 Y-11.424 I-8.353 J3.322
;g2 X-18.003 Y-1.114 I10.314 J4.102
;g2 X-11.36 Y3.479 I9.202 J-6.208
; MOVEMENT_LEAD_OUT
;g3 X-11.137 Y3.84 I-0.069 J0.292 F120
G1 X-11.206 Y4.132
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0.5 F30
G1 Z-1.2
; MOVEMENT_LEAD_IN
G1 X-11.721 Y3.702
G1 X-7.855 Y4.106
G1 X-5.1 Y4.589
G1 X-2.347 Y5.078
G1 X30.876 Y4.619
G1 X33.752 Y4.125
G1 X36.63 Y3.638
; MOVEMENT_LEAD_OUT
G1 X-11.206 Y4.132
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0 F30
G1 Z-1.7
; MOVEMENT_LEAD_IN
G1 X-11.721 Y3.702
G1 X-7.855 Y4.106
G1 X-5.1 Y4.589
G1 X-2.347 Y5.078
G1 X30.876 Y4.619
G1 X33.752 Y4.125
G1 X36.63 Y3.638
; MOVEMENT_LEAD_OUT
G1 X-11.206 Y4.132
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z-0.5 F30
G1 Z-2.2
; MOVEMENT_LEAD_IN
G1 X-11.721 Y3.702
G1 X-7.855 Y4.106
G1 X-5.1 Y4.589
G1 X-2.347 Y5.078
G1 X30.876 Y4.619
G1 X33.752 Y4.125
G1 X36.63 Y3.638
; MOVEMENT_LEAD_OUT
G1 X-11.206 Y4.132
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z-1 F30
G1 Z-2.7
; MOVEMENT_LEAD_IN
G1 X-11.721 Y3.702
G1 X-7.855 Y4.106
G1 X-5.1 Y4.589
G1 X-2.347 Y5.078
G1 X30.876 Y4.619
G1 X33.752 Y4.125
G1 X36.63 Y3.638
; MOVEMENT_LEAD_OUT
G1 X-11.206 Y4.132
; MOVEMENT_RAPID
G0 Z5 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z-1.5 F30
G1 Z-3.2
; MOVEMENT_LEAD_IN
G1 X-11.721 Y3.702
G1 X-7.855 Y4.106
G1 X-5.1 Y4.589
G1 X-2.347 Y5.078
G1 X30.876 Y4.619
G1 X33.752 Y4.125
G1 X36.63 Y3.638
; MOVEMENT_LEAD_OUT
G1 X-11.206 Y4.132
; MOVEMENT_RAPID
G0 Z15 F300
M117 Finish
G0 Z15 F300
G0 Z4.5 F300
; MOVEMENT_PLUNGE
G1 Z0.5 F30
G1 Z-3.8
; MOVEMENT_LEAD_IN
G1 X-11.767 Y3.896
;g3 X-11.406 Y3.674 I0.292 J0.069
; MOVEMENT_CUTTING
;g2 X-10.644 Y3.829 I2.834 J-11.969 F360
G1 X-8.122 Y4.263
G1 Z-3.5
G1 X-5.251 Y4.765
G1 X-2.382 Y5.275
;g2 X-2.213 Y5.305 I15.331 J-85.6
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
;g2 X9.447 Y6.567 I15.162 J-85.63 F360
G1 Z-3.5
;g2 X15.447 Y6.601 I3.502 J-86.892
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
;g2 X28.035 Y5.319 I-2.498 J-86.926 F360
G1 X29.776 Y5.013
G1 Z-3.5
G1 X31.747 Y4.672
G1 X33.718 Y4.333
G1 X35.69 Y3.999
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
;g2 X37.16 Y3.741 I-2.034 J-12.131
;g2 X40.396 Y2.52 I-2.325 J-11.058
;g2 X42.814 Y0.684 I-4.572 J-8.534
;g2 X45.038 Y-2.462 I-7.98 J-8.001
G1 Z-3.5
;g2 X46.085 Y-8.369 I-10.204 J-4.855
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
;g2 X45.322 Y-11.525 I-11.251 J1.053 F360
;g3 Y-17.967 I8.025 J-3.221
;g2 X46.134 Y-22.097 I-10.487 J-4.209
G1 Z-3.5
;g2 X44.581 Y-27.893 I-11.3 J-0.078
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
;g2 X40.012 Y-32.219 I-9.747 J5.717 F360
G1 Z-3.5
;g2 X37.16 Y-33.234 I-5.178 J10.044
;g2 X34.148 Y-33.487 I-2.531 J12.037
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
;g2 X30.374 Y-32.738 I0.481 J12.291 F360
;g3 X-4.317 I-17.346 J-47.052
;g2 X-9.833 Y-33.432 I-4.254 J11.541
G1 Z-3.5
;g2 X-11.406 Y-33.166 I1.261 J12.235
;g2 X-15.445 Y-31.311 I2.604 J10.996
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
;g2 X-18.518 Y-27.939 I6.644 J9.141 F360
G1 Z-3.5
;g2 X-20.102 Y-22.152 I9.716 J5.769
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
;g2 X-19.302 Y-17.994 I11.3 J-0.018 F360
;g3 Y-11.498 I-8.167 J3.248
;g2 X-20.003 Y-8.812 I10.5 J4.176
G1 Z-3.5
;g2 X-19.186 Y-2.868 I11.201 J1.489
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
; MOVEMENT_CUTTING
;g2 X-11.406 Y3.674 I10.385 J-4.455 F360
;g2 X-11.15 Y3.578 I0.056 J-0.238
;g3 X-10.897 Y3.477 I0.205 J0.146
;g2 X-10.594 Y3.533 I2.325 J-11.773
G1 X-8.07 Y3.968
G1 Z-3.5
G1 X-5.199 Y4.47
G1 X-2.329 Y4.98
;g2 X-2.161 Y5.01 I15.278 J-85.305
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
;g2 X9.449 Y6.266 I15.11 J-85.335 F360
G1 Z-3.5
;g2 X15.449 Y6.301 I3.5 J-86.591
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
;g2 X27.983 Y5.023 I-2.5 J-86.626 F360
G1 X29.725 Y4.718
G1 Z-3.5
G1 X31.696 Y4.376
G1 X33.667 Y4.038
G1 X35.639 Y3.703
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
;g2 X37.098 Y3.448 I-1.985 J-11.835
;g2 X40.251 Y2.257 I-2.264 J-10.765
;g2 X42.6 Y0.474 I-4.428 J-8.271
;g2 X44.732 Y-2.516 I-7.765 J-7.791
G1 Z-3.5
;g2 X45.779 Y-8.424 I-9.897 J-4.801
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
;g2 X45.043 Y-11.414 I-10.944 J1.107 F360
;g3 Y-18.078 I8.304 J-3.332
;g2 X45.833 Y-22.017 I-10.209 J-4.097
G1 Z-3.5
;g2 X44.281 Y-27.812 I-10.999 J-0.159
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
;g2 X39.948 Y-31.915 I-9.446 J5.637 F360
G1 Z-3.5
;g2 X37.098 Y-32.94 I-5.114 J9.739
;g2 X34.084 Y-33.184 I-2.469 J11.743
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
;g2 X30.478 Y-32.456 I0.545 J11.988 F360
;g3 X-4.42 I-17.449 J-47.334
;g2 X-9.723 Y-33.141 I-4.151 J11.259
G1 Z-3.5
;g2 X-11.336 Y-32.874 I1.152 J11.945
;g2 X-15.335 Y-31.019 I2.535 J10.704
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
;g2 X-18.217 Y-27.857 I6.534 J8.849 F360
G1 Z-3.5
;g2 X-19.801 Y-22.07 I9.416 J5.687
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
;g2 X-19.023 Y-18.105 I11 J-0.1 F360
;g3 Y-11.387 I-8.446 J3.359
;g2 X-19.694 Y-8.854 I10.221 J4.065
G1 Z-3.5
;g2 X-18.878 Y-2.91 I10.893 J1.532
; MOVEMENT_PLUNGE
G1 Z-4.1 F30
;g2 X-17.92 Y-1.17 I10.076 J-4.412 F360
;g2 X-11.336 Y3.382 I9.119 J-6.152
;g2 X-10.897 Y3.477 I2.765 J-11.677
; MOVEMENT_LEAD_OUT
;g3 X-10.661 Y3.83 I-0.058 J0.294 F120
G1 X-10.719 Y4.124
; MOVEMENT_RAPID
G0 Z15 F300
M400
G0 X0 Y0 F2500
M300 S300 P3000
M0 Turn OFF spindle
M117 Job end
; *** STOP end ***
I think so, I cant say 100% there is not a loose connection, I pulled each cable and checked continuity on each wire, also you can jog the machine faultlessly over the whole axis.
But a good call, thanks for the suggestion.
jeffeb3
(Jeffeb3)
August 2, 2020, 7:37pm
18
It removes the arcs, but it doesn’t replace them with straight lines. So it won’t work right, it will just skip the arcs and move onto the next line.
I think you should try to update Marlin. Sorry if I suggested otherwise a while ago. That might fix the arcs.
The ramps build hasn’t been keeping up, but the next Marlin config does have it back. You can try the new stuff here:
Specifically:
https://github.com/V1EngineeringInc/MarlinBuilder/releases/download/502/V1CNC_Ramps_Dual-2.0.6-src.zip
ok, great I will do that asap, hopefully I will get time in the week, but on the weekend if not and I’ll let you know how i got on.
jeffeb3
(Jeffeb3)
August 2, 2020, 7:53pm
20
No rush from me :). Let us know how it goes.
