Super simple, screw from the inside into the wall and glued the face half of the circles on.
A honey-do which i think may spawn some more.
And yes, it’s just a stick
So if you decided to redecorate, how would you take it down?
We would have to move into feats of strength. It was a known item of the design but truth is with a 5 year old and a 3 year old running the house it’s likely the kids will remove it first.
You could always cut the mounts (or the stick, not sure which is more precious now).
I was just trying to see if i missed somthing, but nope they are a more “permanent” wall mount. At least as permanent as anything is when you have two little ones (i give them 6 months XD kids are the best!)
Ha ha yep. Give it your best shot kiddos.
I’m doing similar with my exhaust mounts, but im drilling and tapping for machine screws instead of glue
I see you haven’t worn any handcuff grooves into it, yet… Of course, with little ones running around, you’re probably better off just using a leather strap lightly wrapped around the stick.
For those of you with some number of children less than two: yes, you can still find time for that sort of thing. How do you think we ended up with more than one?
This was more what I was getting at, good old festivus for the rest of us:
It’s why we have locks on the door.
But for that, you need a metal pole, and there should be an Airing of Grievances!
IT’S A TRAP!!!
