Probably way too fast for this machine. 200mm/s with a .25" upcut spiral endmill.
I had it at 300mm/s, but this happened…
Think it caught a hard piece in the plywood somewhere that caused the bit to cut into the side. I was already two passes in, so about 4mm deep, this caused the router to overcome the holding torque of the steppers and it was off to the races!
