Does anybody knows what gcode that estlcam runs to set x, y & z axis to zero so one can start working from any part of the work area? I am asking this because for those of us having SKR boards, we cannot use estlcam as host controller. I uses repetier host and I do not see this particular function on the application. However, if I know the gcode then one can simply send this code.
Also, I know I am doing something wrong because when I tried to cut my first piece on my new Primo, and I placed the z-axis on the workpiece (I verified that I set the start point as lower left and top of workpiece), when I push run on the display screen, the z-axis moves up and cuts nothing (verified that z-axiz negative move is towards the bed as I can see the it does goes down during the cut, but it is too far away playing “air guitar”).
I will appreciate any assistance as always.
