I am thinking about building a mpcnc but I don’t know much about cnc machines. I want a versatile machine, one that can easily handle aluminum (I would assume that it would then also do fine on other, softer, materials (wood, plastic, carbon fiber)). I would like something that is fairly quiet and also below $150 (including power supply and any controller).
So my question is what spindle or router should I get?
Do I need to be able to control the rpm with software, just use something like a potentiometer (like some spindles off ebay), or does it not need variable speed at all?
With the Dewalt I wouldn’t be able to adjust the rpm of the router. Is that a problem for aluminum? Is it important to be able to adjust feeds and speeds in the software?
If I went with the recommended 500W spindle instead, would that be better for aluminum?
Sorry if these are obvious questions and thanks for the help.
