Building some Paulk workbench clones. Actually just one right now. Eventually will have two. Using the not as cheap half inch-ish birch plywood from Lowes. Was going to just make templates and cut the rest with my hand router, but it’s only taking about 10 minutes per cut, and not messing up, so I’m letting the cnc do it. Will have to make a template for the top though. I can’t fit the bench top on the router. Mid span supports are in the way.
