My SKR motor controller board is working, motors step etc, as is the TFT35 display, with just one little problem. The TFT end thinks it’s a 3D printer. I’d really prefer it to think it’s a MPCNC router. What am I missing ?
Yes - purchased fromV1. SKR Base board V1.2, TFT35 V3.0.
I had a problem with a damaged backlight, but assumed no code running. Backlight now sortof repaired. The two boards are working OK, touchscreen mode, single cable.
I have flashed both the screen and the SKR base board. With what - I’m at work so unsure
The prompts on the TFT are for a 3D printer (fans, extruder etc), expected MPCNC prompts.
The v1 touchscreen firmware has cnc style prompts. Does it show the v1 logo when it boots? There is also a cnc mode in the ini file that needs to be 1.
