I just finished assembling hardware and 3d printed parts for MPCNC build.
before I place the stepper motors in trucks, I wired everything to make a test run but unfortunately not all steppers work. X, Y, and Z are working fine but X2 and Y2 are not working.
I flash the V1CNC_Rambo_Dual-2.0.7.2-src firm wear into Rambo 1.4
I still don’t connect endstops
The current release point for firmware is here. Even an old version of the Rambo Dual firmware should have had X2 and Y2 moving, so I’m not sure what is going on. Update to the lastest version and see what happens. Note you may need to make firmware changes to support this screen.
Even that firmware is based on bugfix-2.0.x. You didn’t successfully flash it.
Get the latest from MarlinBuilder releases (which is the same zip that Robert pointed to, but presented a little more organized) and use Xloader to flash it.
