I just finished the wiring and can get repetier host to move everything in the direction I expected. The Z axis was the only exception but I inverted that axis to solve the problem.
My only question is when I move my Y axis it is significantly louder than my X and both are louder than any belt driven 3d printer I’ve used.
What could be my potential issue and solution to this problem? Could I have tighten to the bolts too much on the Y axis?
Also it seem like the gantry has more wiggle room in it than I expected. How can I tell if I have too much wiggle room and what I might need to tighten to resolve this?
I didn’t get anything from the store. I printed my own parts, sourced my own electronics and ended l even built my own wiring harness, which I’ll never do again. It wasn’t worth my time.
Is there a possibility that the belt is just too tight?
I’m going over the FAQ to make sure I’ve done everything I can.
I don’t think it’s the stepper motor voltage because I set all of them at or around .7 volts. I’m not sure I’d call the noise a wine.
@Barry, I can pay a video when I get home tonight. It will probably appear after 10 pm est just to give you a heads up. I hope the video will clarify the noise situation.
I have DRV8825. They aren’t ear piercing but I found it strange that they are set to a very similar voltage but they aren’t making the same noise level. When I did try and run gcode through their system it was quieter than my metal music so it seems that this only happens when I try to run it manually.
