Hi guys,
I tried engraving some PCBs on my mpcnc today. But after a few minutes the Y axis starts to move when it should not move. Lines that should be only in X Direction start to drift of in Y Direction. The problem is not on the gcode (which is generated by pcb-gconde ulp in eagle) since the problem occurs on different locations on every try. I turned down the maximum speed all the way to 200 mm/min but nothing changed. My next thougt was that maybe the stepperdrivers overheat, switch of and the spindle drags the axis away from its path. I monitored the temperatures for a whole run and they never exceeded 30°C which i think should be fine.
Do you have any more ideas what could cause this problem?
Thanks,
Philipp
My setup:
eagle -> pcb-gcode ulp -> estlcam -> arduino with cnc shield and a4988 drivers (GBRL all in estlcam) -> mpcnc with 1 meter conduit (~73 cm working area) and makita rt0700 spindle
If the current is too high the motor driver could go into thermal shutdown and then it has no torque (intermittently). Try again (no spindle, just moving in air) and tug on the motor periodically to see if it still has torque after a while. Actually you don’t need to run a job for this, just let it idle with steppers engaged and see if it cuts out intermittently.
Since i already suspected a thermal shutdown i already tried pulling on the axis while idling. I did not notice any weakness. But i only did it once and not periodically. I will try that tomorrow.
The current is set to 1A.
The crown was successful and also plotting with a drag knife works fine.
The only thing attached to the gantry is a drag chain, but it is not pulling on the gantry. I’ve tried removing the drag chain…but got same results.
Hi again,
sorry for not answering in a while. But i solved the problem. It was indeed a overheat problem. I replaced the fan in the housing with a much stronger one and now it works flawlessly.
