So my home position when I home X and Y is 0,-17 X=0 and Y is -17mm
I entered the y home position in the printer specs as -17, and y min as -17.
So after i click to home Y axis then try to move the y axis it grinds trying to move the specified distance in the wrong direction against the end stop. The very next time I try to move Y it responds as normal. Not sure if I explained that in a way that makes sense… So if I did these actions in this order this is what I would end up with
Home Y
Y 5
Y 5
It would show on the screen that Y was at 10 but is actually at 5
I do not understand why it is trying to move in the wrong direction the first command after homing Y. Any thoughts?
