A farther away picture of the gantry. I haven’t decided if the air hose (shiney black) should go with the other cables, or hang it from the ceiling. I will glue it to the nozzle though. It keeps popping out.
You can see my previous attempt hanging on the close side. I use that for pens too. But I may make a router base mount for pens as well.
The can part of the mount is actually an ellipse, so it holds in place with a bit of a spring action.
I went through a couple different riggings/routings of my air assist line. I use a larger aquarium pump for my air. I noticed the longer runs suffered a substantial pressure drop compared to the shorter runs. I imagine that a LowRider will require even longer runs, but that could be offset by using a compressor instead of an aquarium pump and/or by using larger tubing. But one thing I considered doing which would work to keep runs short for a LowRider was to hang the pump above the middle of the work surface. This would keep the air assist lines shorter. I initially ran across the idea of hanging the pump as a suggestion for making an aquarium pump quieter. In the end I went a different route, but it stuck with me as an interesting out-of-the-box solution.
I can assure you that it works wonders to quieten (a word?) the pump… I have it hanging from a length of surgical tubing. At times, I literally have to go touch the pump to see that it is running…
I also noticed longer runs suffered substantial pressure drop so use a larger diameter (~6mm ID) length of vinyl tubing to get as close as possible to the ball-valve and nozzle…
I get my air from a compressor in a adjacent room. Works great, the noise is fairly dampened by the walls. The only thing is that the outlet builds up ice on cold days… the compressor is in an uninsulated room. So after running the laser for a while, air starts leaking because of the ice buildup. And if I unplug the hose, the autovalve doesn’t close and the tank empties with one hell of a noise…
I took a few minutes and tried the focus script in light burn. It is very similar to the focus script from Ryan, but it has these nice labels.
I let it choose the defaults of 50mm/s and 20% max intensity. 0-10mm Z. I started with the air nozzle touching the board and I set that as Z=0.
For some reason, it is mirrored. My machine isn’t mirrored. At least I am pretty sure I have that right.
There is also some very pronounced on/off pattern. Either this speed is too high (50mm/s), or more likely, I need to increase the PWM frequency on this board. Maybe both.
As I said in the first post, I have a very early grbl_esp32 board made for the MPCNC. There are some tricks to swap X and Z to make it work for the LR. I have done all of that and checked it out. But it was a while ago and I don’t see some of the modern laser features in the terminal. So I think the next step is to probably try to flash new working firmware and test it out again. While I am at it, I may try to swap Y and X too, so the LR cords make more sense for where I stand near the machine.
Does anyone have an idea of a good PWM frequency? I don’t think I have unlimited choices, but I can get it close.
Alternatively, I could try dropping the speed to 10mm/s or so and trying that again. The dots would just be 5x closer.
Even with all of that. I think I have about 3.0mm or so for a good focus distance. That makes me wonder if I did something wrong. Like maybe it wasn’t really touching the board completely, or the board lifted when I wasn’t looking. Based on Dave’s analysis, I thought 5-7 mm was more like it.
I’m not crazy. This gcode is mirrored. I think it is because I chose a non-default origin location in lightburn. It was also trying to draw at 420,620 or so away from the origin (which I noticed and fixed with work offsets first).
TODO:
Change LB back to normal origin
Update firmware and check motion
Swap X and Y so the place I like to start the gantry is 0,0
I think the dark ends are the constant vs dynamic power during accel/decel… M3 vs M4.
The origin stuff can be tricky to get set… and I’m sure are responsible for the mirrored images. There are a couple of different places in LB where machine/user origin(s) can be set… I usually use lower-left.
I’ve got a bidirectional M4 version of Ryan’s focus script that seems to work well…
Nope, this is grbl, but forked a long time ago for the ESP32.
I agree. It is setting the laser on with M4, and then using S200 in the G1 commands. I think that looks ok, but I think it is varying the duty cycle of the PWM correctly, but the PWM frequency is too slow, so it is off for 10ms or something, and then on for 2ms or less, but that results in very wide gaps between the dots. Instead, if it was on for 2us, and then off for 10us, it would be super tiny dots that would be a lot smoother.
That’s just my guess. I have really just been skimming the laser posts in this forum. I have no idea if the neje laser can even toggle faster than the current PWM (but I suspect it can).
I have been caught sleeping. There is a new version for the ESP32s that Bart has been working on. FluidNC. I will see if I can get that working instead. It looks pretty slick:
I’m having a bit of trouble concentrating so please forgive if I go off the rails. Been puny for the past week – tested positive for Covid, quarantined for 5 days, just tested again… NEGATIVE! But still have cold-flu or respiratory infection to deal with… still puny.
Not familiar witih LB focus test and confused by “dots”… should be constant powered for length of line. LB has “constant power” button on Cut/Layers window… does that have an effect?
I think you’d have better luck with Ryan’s focus script… it’s simple and easy to understand. I’ll also try to find my M4 version…
I added some spaces to make it easier to read. It is going from Y=590 to Y=610 (and the laser was previously turned on with M4, the power is set with S200 and the feedrate is 3000mm/min, or 50mm/s). You can see in the actual burn that the laser is turning on and off over that move, at a fixed time period. When the gantry is moving slow (at the start and end of the burn) the dots are close together. In the middle, they are a little farther apart. I don’t think there is anything that Lightburn could be doing differently in those lines of gcode. The responsibility has to be with either the laser or the firmware. My guess is firmware. Specifically, I think I need to configure the PWM frequency to be higher. That may be something that isn’t a problem in Marlin or grbl (because the default is fast enough). It may not be a problem in the newer FluidNC either, I have to update to find out.
That looks pretty succinct. It doesn’t have the number labels on it, but it is doing something similar. The big difference is the 50% power and the 1000mm/min. It also is scanning left and then right, instead of always right in my script.
Yeah… bidirectional = quicker
Nah… no fancy labels
Set appropriate speed power in one place for your laser.
I just count lines back to finest and multiply lines by 2mm. Lower that much… viola!
I’ve actually become a fan of using a gauge block more often than this script… it’s quicker. Although running it to confirm accuracy of gauge block isn’t a bad idea… need to do only once?
I find that setting the gauge block on the material and then simply running the laser head down until it “eye-balls” good enough works for me.
Oh, my! Doesn’t look like me or any stick I’ve ever made… but I appreciate being honored and immortalized in such a unique way! Thank you – EVERYONE – who has made this possible!!!
