This allows connecting a 2.5" hose from a Vacmaster Pro shop vac to the LowRider 2.
Includes both a Dewalt version and Makita version of the “VacShoeTop.” (The original default “VacShoeTop.STL” should not be used, as the redesigned ones offered here allow more airflow. See notes on airflow below.)
My Vacmaster Pro shop vac came stock with a 7’ hose. I bought a second matching 7’ hose at the home improvement store. I used the coupler I designed (included in this setup) to connect the two hoses. The stock hose ends with a long plastic sleeve. The second hose (bought as an accessory) has a matching long plastic sleeve on one end, and a short plastic sleeve on the other end. Match the two long sleeves into the coupler. The short sleeve on the end then goes into the adapter I designed (included in this setup) on the LowRider 2’s router plate.
Notes on airflow for this Vac Shoe Assembly for Vacmaster 2.5" Hose:
- Unobstructed circular opening for the hose (ID) has an area of 3,017 mm²
For comparison:
- Opening in the router plate (Makita version) has an area of 4,035 mm²
- Opening in the router plate, less the round area directly under Makita, has an area of 2,959 mm²
Of importance is approximate size of the “mouth” at bottom of this “vac shoe” set-up. That’s not as easy to calculate, so I did not. Instead, this is a poor approximation that I calculated that by adding together the horizontal footprint (1500 mm²) and the vertical “face on” footprint (800 mm²), which comes to 2,300 mm².
I drew inspiration from this item:
‘Low Rider V2 - 4" dust collector adapter’ - Low Rider V2 - 4" dust collector adapter by Tailslide - Thingiverse
…and I remixed from these two items:
‘Lowrider2 Makita RT0700C Plate and Vacuum Shoe’ - Lowrider2 Makita RT0700C Plate and Vacuum Shoe by frederikkemner - Thingiverse
…and the original LowRider 2’s “VacShoeTop.STL.”
Note: My stock hose fits perfectly in the coupler, but the second hose is a bit loose. I wrapped a rubber band around it, and pushed the coupler over the rubber band, getting part of it in between the hose end and the coupler. This provided a tight fit.
PS: This also means I will now need to remix my pen holder, “REDUX LowRider 2 MPCNC - Pen Holder (v2) MOUNTS CLOSER” available at the link below.
… If I can get a new version of the pen holder designed, so it works with this hose adapter, I will try to come back here to link the new version.
