For some time, I have been planning an MPCNC build, and today I ordered the kit of parts. I already have the EMT conduit, 3D-printed parts, and table parts.
I will update here when I have pictures.
Some information on my build:
24x24 in work area, I might make it smaller if I experience precision issues
Primarily meant for milling aluminum and wood, maybe some brass
I am using an SKR Pro board and TMC2209 stepper drivers, with the dual endstop setup
I have built several tables like this and diagonal braces are by far the biggest gain, even if they are thin. I use 2x2’s and they are more than plenty strong and stiff since the diagonal braces only experience axial loads.
I haven’t fixed anything to the table yet since my table surface is uneven. Sometime next week, I will buy the OSB and plywood to sheath the table, add a shelf, and replace the surface.
Update: I have received my endstops and started wiring everything. The only thing I am waiting on is the control board (SKR Pro), which should arrive relatively soon.
I have a new version of the table CAD, which I will be building:
