Hello All,
Love the machine, loved building it.
I build a full complete kit from MPCNC.
It went together nice, following the directions.
I am running Widows7, Estlcam 10.
The control panel in Estlcam moves the Gantry in all the correct directions.
I built it 40"X40", which gives me about 29.5" square cutting area. 5" legs, and a 12"Z Axis.
When I practiced with the pen attachment, Z did not raise off paper between line sections.
Then I tried to put my dremel on the Gantry, all snugged up.
I am saving for the Dewalt router.
Tried practicing on a piece of foam board. Still Z is not raising above the plane of the material.
I set the Z axis to zero with the tip of the bit touching the top of the foam.
It goes down a little and begins the design.
never lifts above the top of material.
I saw in the Estlcam instructions to reverse the Z direction.
When I tried that the control panel move Z in the opposite direction,
When I run/ machine the design it lifts up and never touches the material at all.
Please help me, I am sure it is just an ID10t error on my part. probably just one small thing I am missing.
Some pictures enclosed below.
Thanks in advance for any and all help
George in NEPA
