I was thinking that for your next iteration, you consider making one of the Y plates sized to accommodate direct mounting of the controllers and an RPI to help clean up the installation. You’ll have to change the size of the particular plate because the controllers don’t fully fit on the current V2 version. You could size it and add holes for each of the three types of controllers you sell to the left of the stepper and holes for a RPI to the right of the stepper. You could also offer 3-d printed covers (maybe snap-in to slots on the plate?) This is what I’m looking to cut to stand off from the current plate to allow me to mount my controller & rpi…
The left is for the mini rambo, the right is for an rpi4, and the bottoms slits are for zipties to hold down a small power strip. I could use this as the Y-plate itself, but I don’t want to tear the plate apart now that I got it all put together. I’m also trying to figure out if I should add a spool or two for cable management.
I don’t think the controller, RPI and a very small power strip really adds much weight. I’ve already got all that dangling off the current y-plate as it is and everything seems fine… it’s just an utter mess.
For my new piece to standoff and mount everything to, I plan to use the thinnest board I can get to keep the weight down…
True… right now I have it zip tied together with my small power strip… Maybe keep it that way with the power supply up against the plate and the power strip out in front of it, all zip tied to the plate… if you follow. The power supply is flat so I think it will work. For my installation where I’m standing off the new plate, I might put the power supply on opposite side of the new plate from the power strip… and zip tie it all up.
My concerns would be having too much heat generated in a small area and having ready access to the connectors and such. Also the mounting hole locations are different so you’d need some bracket or something to stack them above each other.
That piece of 3/4-inch plywood probably weighs more than everything attached to it. My plan is to stop by Office Depot, pick up a couple legal size clipboards (1/8-inch hard board), cut off the paper holder thing, and use the material to cut the plate for it. The staff there wonders why I come in so often to buy clipboards, but its cheap source of 1/8-inch material and I don’t have to have it shipped in.
